O2 signal
I’ve recently purchased 2 iPhone 8 Plus’s. The 3G signal is not as good as my iPhone 6 Plus. The difference when I look at the mobile data is that the new phones are connected to the O2 signal which bizarrely doesn’t work well in my house...can I transfer them to the old 3 network?
Posted From Apple iPhone
Re: O2 signal
Hi there, can you PM us your number, name, full address and DOB? I'll check this out 👍
Re: O2 signal
Pm sent
Re: O2 signal
Hi there, we have got back to your PM 👍
If you haven't already registered, now is a good time to do so. Register now >>
