Activate replacement SIM
Hello, there is a problem with my SIM card that came with my new phone. So I was advised to go into a three store and purchase a replacement SIM card, which I've done. So can anyone help me activate this new card as I need my phone for work tonight please
Posted From Android 2.0
Re: Activate replacement SIM
Posted From Sony E5823
It's saying my phone number is not recognisable??
Are you just putting in 08xxx
Yes, do I need to put in 353?
No, I put my existing number 087xxx into the box on the first webpage and it went into next page
But I haven't got an existing number, it's a completely new bill pay contract. The new SIM they gave doesn't work?
Ok contact one of the mods here or ring 1913 or +353 83 333 3333 to activate your new sim card
Hi @Jwest 👋 I've replied to your PM so if you pop back to me there I'll get this sorted for you straight away. Ashlee
