Roaming in Croatia? Huawei
New Member
Hey,
I am currently in Croatia and I am using the Unlimited Fles Max plan so I should have some free minutes, sms, data etc. but the thing is that I cant connect to any network there manually or automatically so I have just emergency calls.
What should I do?
Thank you.
Re: Roaming in Croatia? Huawei
Solution
Accepted by topic author LegioXII
‎28-07-2017 05:14 PM
Staff
Hi @LegioXII can you PM your number so I can get this investigated for you.
Change setting to manual, and restart phone
Did you check your settings on 3 website?
Posted From Android 2.0
New Member
I tried to change to manual and restart phone but still the same. About the settings on 3 what should I look for?
Thanks.
On the LHS if you goto My Settings
My settings.
Using your phone abroad.
You can make calls abroad whilst in countries listed under Prepay. For price details go to three.ie
> More information on making calls abroad
To change your international roaming settings, you need to call Customer Services on 1913 free from your Three mobile or 083 333 3333 from any other phone.
Internet access settings.
All usage abroad will not come out of your monthly allowance but will be billed to your account.
You are set up to access the internet in Ireland and abroad.
Choose where you want to be able to use data:
New Member
Alright so I have the same settings. Ireland and abroad internet access marked.
Interesting is that I was connected on network in Osterreich, Slovenia but when we moved to Croatia then it was all gone, no signal just emergency calls.
add: Everyone else around here are connected on some network. They dont have 3 tho.
Thank you.
Solution
Staff
Search the Community
Top Liked Authors
User Kudos Count
19
1
Hot Topics
How to turn off the Adult Content Filter
World Photo Day Competition 📱
