Network Unlcok Pin?
Trying to use my 3 sim on a Sony Xperia phone will my iPhone is being repaired, but its asking for a network unlock pin. Is there any way to get this pin? Thanks
Re: Network Unlcok Pin?
Hi there,
Is the Sony a Three phone? If not it will need to be unlocked by the network.
No its an 02 phone but was wondering what to do as they're part of 3 now
Can you PM me your full name, the IMEI number of this phone, your address and date of birth and I'll look into this for you?
yeah sure, will do now thanks!
