Huawei P10 plus headphone queries
I just bought a new earphone that has a volume buttons but unfortunately when I press the + volume up button, it changes to the next song and the - volume button, it goes to the previous song. Can someone help me on how to fix this please?.
Posted From Huawei VKY-L09
Re: Huawei P10 plus headphone queries
Posted From Sony G8441
Hi there, it sounds like there may be a fault with the headphones. Did you buy these in store?
No fault with headphones, they are just reversed polarity that your phone needs
Try the sony app smart key to change behavior of buttons.
http://aptgadget.com/best-apps-control-adjust-headset-button-android/
If you haven't already registered, now is a good time to do so. Register now >>
