Android Settings
by Community Manager ‎03-03-2015 02:38 PM - edited ‎15-06-2017 04:14 PM (23,456 Views)
Need the internet/MMS settings for your Android device? Look no further!
Here are the generic APN (Access Point Name) settings, which are normally found under Settings – Mobile Networks – Access Point Names.
Different phones may not require all of these, or they may be worded slightly differently. If you’re unable to edit the current settings, press the Menu key to add a new APN.
The settings are as follows:
APN: 3ireland.ie
Proxy: not set
Port: not set
Username: not set
Password: not set
Server: http://mobile.3ireland.ie/bb/HutchKey/
MMSC: http://mms.um.3ireland.ie:/mmsc/
MMS Proxy: mms.3ireland.ie
MMS Port: 8799
MMS Protocol: WAP 2.0
MCC: 272
MNC: 05
APN Type: not set
Once they have been entered, back out to save them and restart your phone.
If you're having trouble, check out the screenshots below:
Still have a question? Let us know in the comments.
Comments
by Dljitx
on ‎22-06-2016 12:49 PM
Hi, are the APN settings the same if you were previously an O2 customer? My wife can't get any Internet on her phone at all whilst out of WiFi range and she has been topping up with €20 or more a month?
by Moderator
on ‎23-06-2016 12:16 PM
You can check your mobile internet settings are correct at this link: http://bit.ly/1PXHsHx
by Tealyturtle
on ‎09-12-2016 03:33 AM
Hi I just got a Samsung galaxy core prime put my SIM in and followed the setting instructions as requested but I'm still unable to use the internet or won't connect 2 my WiFi
by Moderator
on ‎17-12-2016 11:00 AM
Hi there, do you have your mobile data switched on?
by Staff
on ‎06-07-2017 10:49 AM
Delighted to help @yahootech 👍
by Antodj36
on ‎08-08-2017 05:51 PM
Hi I have an sitcom.net email address but I cannot configure the outgoing mailbox to send mails. Can you advise the server address please?
by Moderator
on ‎09-08-2017 09:10 AM
Hi Antodj36, the SMTP for Three is: mail-relay.3ireland.ie
Search the Community
