  • Three_Sheena
  • 03-03-2015
  • 29290
  • 3
Android Settings
by 3 Community Manager on ‎03-03-2015 02:38 PM - last edited on ‎12-12-2017 03:13 PM by 3 Moderator (29,290 Views)
Need the internet/MMS settings for your Android device? Look no further!
Here are the generic APN (Access Point Name) settings, which are normally found under Settings – Mobile Networks – Access Point Names.
Different phones may not require all of these, or they may be worded slightly differently. If you’re unable to edit the current settings, press the Menu key to add a new APN.
The settings are as follows:
APN: 3ireland.ie
Proxy: not set
Port: not set
Username: not set
Password: not set
Server: http://mobile.3ireland.ie/bb/HutchKey/
MMSC: http://mms.um.3ireland.ie:/mmsc/
MMS Proxy: mms.3ireland.ie
MMS Port: 8799
MMS Protocol: WAP 2.0
MCC: 272
MNC: 05
APN Type: not set
Once they have been entered, back out to save them and restart your phone.
If you're having trouble, check out the screenshots below:
Still have a question? Let us know in the comments.
